Landscape Problem in N95
5 replies · 3,116 views · Started 25 July 2007
[CENTER] i bought N95 V (11.0.0.26) mobile and its great in all APPS EXCEPT one thing (the camera) in landscape or in Auto option it gives me very bad quality photo when I show it in Computer,
the nokia N70 Mobile show me better photo
All the camera setting is in all high Quality (5M)
No problems In video Or close Up or portal options the problem only in Landscape photo it is not clear at all
I Update my mobile to V 12.0.0.13 but still the same problem no quality photos
ANY ONE HAVE THE ANALYSIS FOR THIS PROBLEM [/CENTER]
have you tried to print a picture? it might be a resolution issue with your pc? Do the pics look fine on the N95 when viewed?
osg wrote:have you tried to print a picture? it might be a resolution issue with your pc? Do the pics look fine on the N95 when viewed?
Than you for reply >>>>
the printing photo was too bad and the photo in mobile also bad...
the things that will make my craizy that the video and close-up mode is very nice even after print
I try many other mobiles and other computers and my mobile show the worests photo in landscape mode
Hmmmm.... have you returned the phone to where you purchased it to show them alsary??? It may be faulty? How old is your N95?
you are focussing before taking the picture?? just that video doesn't require it. half depress shutter until focus box turns green.
alsary2004 wrote:[CENTER] i bought N95 V (11.0.0.26) mobile and its great in all APPS EXCEPT one thing (the camera) in landscape or in Auto option it gives me very bad quality photo when I show it in Computer,
Yes, there appears to be something wrong with Landscape Mode.
I went to Blackpool yesterday took loads of nice photos in landscape mode. Unfortunately, they are all blurred, Or what appears to be watercolour effect (watercolor for the American searches).
Checkout the sample landscape pictures for:
h t t p : / / w w w .symbian-freak.com/forum/viewtopic.php?t=11005&s=phpBBMobile
If it happens on Auto, I can only assume the N95 decides you�re taking a landscape picture; therefore it uses the landscape photo.
I will do some tests tonight to find out what�s causing the problem. Under user defined settings, you can base the settings on another profile. If I base the settings under Landscape, then adjust the other features, such as exposure until the effects disappear.
I will post my findings.
Im a newbie here, but couldn�t help but registering because of my new N95...
By the way, also whilst on my Blackpool trip, I left my GPS running, took pictures, made 20 min call, kept mail for exchange running constantly with data connection, Battery lasted max 5-6 hours
Lesson learnt, GPS took up most the power, without the GPS, my phone would have made it back to base whilst using other features.
Tom
