Streaming audio over bluetooth
8 replies · 3,330 views · Started 26 July 2007
Hi all,
I Seem to be believe I read somewhere that the N95 can stream mp3s etc. over bluetooth. If this is the case does anyone know of a device that could stream this to a car stereo, I am not sure whether standard bluetooth car kits do this or if I need something special.
Thanks for your help.
Mark
Not really clear what you mean!
Do you have an external input or a B/T enable car stereo?
Sorry to clarify I have a car stereo with an audio input on the back (red/white RCA plugs). I want something to plug into there so that I can transmit mp3s (and also navigation) to my my stereo. I see parrot do a car kit that will do this but I am not in need of a car kit, I do not make calls whilst driving.
Mark
rorrism wrote:Thanks mate.
Thats looks great, so am I correct in thinking it runs of AAA batteries?
Mark
Bluetooth specification v1.2 class 2
Supports Bluetooth headset, handsfree and A2DP profiles
Rechargeable 230 mAh li-polymer battery
Talk Time: up to 6 hours^
Music Playing Time: up to 6 hours^
Standby Time: up to 150 hours^
Nominal Charging Time: within 3 hours
Compatible i.Tech 110 ~ 240Vac Switching Power Charger
Dimensions (main body): 53.3 x 25.5 x 26mm
Weight: 23.8 grams
I've had one of these for a couple of years now and it's great!
It has its own internal rechargeable battery and comes with its own mains powered recharger unit.
gordslaphead wrote:I've had one of these for a couple of years now and it's great!
Sorry to be pedantic, but, didn't I just post that info above?
rorrism wrote:Sorry to clarify I have a car stereo with an audio input on the back (red/white RCA plugs). I want something to plug into there so that I can transmit mp3s (and also navigation) to my my stereo. I see parrot do a car kit that will do this but I am not in need of a car kit, I do not make calls whilst driving.
Mark
You could use the a/v cable that came with the N95 to plug the phone straight into the stereo. Not as elegant as a Bluetooth solution, but cheaper...
