On my Nokia 6230 i could skip songs when i pressed the answerbutton on my headset (the litte control where you change volume) but it doesnt work on N73. If i press and hold the button the voice-command starts. I haven't found any settings. Is there any way to configure this?
Thanks!
It's never worked, which is a pity..
I'm on my fourth firmware upgrade and even with the new-style ME player it doesn't work.
Notably though, the voice recognition now does work with 4.0727.2.2.1. It never did previously.
I use the Nokia AD-41 headset adapter and it has dedicated transport controls which work very well indeed. It also allows you to use proper headphones with 3.5mm jacks and not the awful OEM ones 😃
These can be had at a very good price from eBay.
I got my fingers burned with one of those.
Bought it off ebay and it was a crap fake from Hong Kong (even though the item location said Norwich).
Took me ages to get a refund.
On the look out for a HS-12W now to take advantage of the A2DP :biggrin: .
