I can't figure it out how to manage the equalizer 😞((( i activate EQ1 EQ2 or EQ3 with their defaults . But there is NO WAY i can edit them somehow? for example if i activate EQ1 the bass is very strong and it sounds ugly. i want to make it lower but dont know how.
anyone use ALON mp3 player for 6630?
mlegs wrote:I can't figure it out how to manage the equalizer 😞((( i activate EQ1 EQ2 or EQ3 with their defaults . But there is NO WAY i can edit them somehow? for example if i activate EQ1 the bass is very strong and it sounds ugly. i want to make it lower but dont know how.
i already used alon mp3 player.. i think it can't be modified.. that's preset.
and other thing that really bad is that when you select random it will play as randomized, but if you exit the player and play as random again, the second song will be played again even if you selected random option..
The application is provided with help, isn't it? Keep pencil key pressed and move the curve left, right, up or down with the joystick. Pencil + press the joystick to increase the lenth of the curve and pencil + 'c' key to shorten it.
no
