Maploader 1.1 truble
7 replies · 3,641 views · Started 26 July 2007
Hi
How can i get the new maploader 1.1 to work with my N95?
Have the new FW and installed maps update.
But everytime i try to install a map with maploader the very anoying:
"Connection to the storagemedium has been interrupted. Attach your storage medium and retry"
shows.
I have formated the memmorycard, done the *#7870# and installed all again.
Same story again.
So, please help me to get this to work :redface:
Could be any number of things, for instance, the phone trying to sync with Outlook, if you use that feature.
By far the best way to install the maps is to put the card straight in the computer's card reader (if it has one, of course). Much, much faster.
I Agree
Halon wrote:Could be any number of things, for instance, the phone trying to sync with Outlook, if you use that feature.
Don't have a cardreader 😡
But now i ordered one from ebay so i just have to wait for that.
davyjones wrote:got same problem, used another compuer and it worked.
so try that.
Mines update didn�t work at first either, so I turned of pc for the night and tried again the next day and it worked without problem! My guess is that it possible just needed a restart for some odd reason!
Now it works :icon14:
I dualboot my computer with vista and XP and when i reinstalled all stuff from XP it works!
