Longer startup time after update to 4.0726.2.0.1
2 replies · 1,800 views · Started 27 July 2007
I updated my N73 to V4.0726.2.0.1 yesterday and all went fine until i power off the phone and restart it. What i noticed is that the phone takes about 1.5 minutes to get to the enter pin code dialog after i press the power button. It's a bit annoying having to wait for more than a minute to restart the phone. Can anyone suggest a solution to my problem and does anyone experienced the same problem as mine before?
hi,
have you got many apps or music stored on your memo card, cos that can effect startup times. try starting up without your memo card inserted and c if thats any improvemnt then least you`ll kno where the problem starts. i have nothing on mi 2gb card at the minute and from power on to pin screen it takes around 20seconds then a further 3 to standby screen!
andy
