Does Anyone Know?
2 replies · 1,394 views · Started 27 July 2007
Does anyone know when Orange are going to make V12.0.0.3 firmware available for the N95? I take it the product code depends on which network you are on right?
Seejay89 wrote:Does anyone know when Orange are going to make V12.0.0.3 firmware available for the N95? I take it the product code depends on which network you are on right?
I�ve got a friend who works for Orange and I asked him when they will release there V.12 update for the N95 and no one seems to know. If your phone is really staring to play up then you might want to look into upgrading to V.12 generically. Downside being you will lose the Orange touches (which is great for some!) and also lose the ability to use Oranges 2 phone lines.
Zayshan wrote:I�ve got a friend who works for Orange and I asked him when they will release there V.12 update for the N95 and no one seems to know. If your phone is really staring to play up then you might want to look into upgrading to V.12 generically. Downside being you will lose the Orange touches (which is great for some!) and also lose the ability to use Oranges 2 phone lines.
That�s the only way to know, ask Orange!
