Process manager for N95
5 replies · 5,801 views · Started 27 July 2007
I've been looking around this site (s/w and forums) to see if there's a "process manager" application for the N95/S60v3 - that is, an app which can show me which programs and/or processes are running on the machine, and identify any misbehaving ones so I can 'kill' them if necessary.
So far, I found a couple, but one appears to be for UIQ and another looked like an earlier S60 version. I'm so used to having some kind of process-monitoring utility(ies) on a computer (e.g. "ps" on my Linux boxes), that it seems strange not having the same control on my N95!
Any suggestions?
Many thanks 😊
tawalker wrote:I've been looking around this site (s/w and forums) to see if there's a "process manager" application for the N95/S60v3 - that is, an app which can show me which programs and/or processes are running on the machine, and identify any misbehaving ones so I can 'kill' them if necessary.
Any suggestions?
Many thanks 😊
I am looking for the same lol
there is also Best TaskMan for S60 V3
and I quote
Description :
TaskMan helps you control your device better. It shows full
information about device memory, running applications,
processes, opened files and installed applications. The software
allows extended applications management and much more functions to explore.
I hadn't thought of that one, even though I've heard of it - Steve Litchfield talked about Best TaskMan for task-switching, but I didn't realise it could monitor processes too.
Will have to look into it further - thanks for the heads-up, everyone! 😊
