Whats the best site for buying 4GB MicroSD HC cards?
I know its around �40 everywhere, but where is cheapest (keep P&P in mind) and most importantly, where sells geniune memory, as I know there are alot of Sandisk fakes around.
play.com do them for £34.99 with free P&P
just checkd they are out of stock though at the moment
Do they play.com ones come with the free USB reader?
I always thought it was included in the packs but it doesnt mention it on the site.
try memorybits.co.uk
I got mine from MobyMemory but it was �50 but it was an original Sandisk with the usb reader and converter for standard SD.
Mobymemory seem to have them for £40 but not available until end of month.
I think I'll be going with Memorybits becuase it seems to be cheap and http://www.memorybits.co.uk/shop/micro-sd--transflash/sandisk-4gb-micro-sd-hc-transflash-card-plus-adapter-plus-micro-mate-card-reader-for-use-in-n95-sdsdqu4048e10m/4921
do they include the card reader as it doesnt exactly say?
Blueunplugged have 4GB microSD cards.
Original Nokia at �49.95
http://www.blueunplugged.com/p.aspx?p=120672
Or SanDisk at �38.95
I bought this one:
http://www.datakits.co.uk/store/4gb-sandisk-microsd-microsdhc-memory-card-p-3837.html
I belive it's orginal Sandisk, isn't it?
[email protected] wrote:Blueunplugged have 4GB microSD cards.
Original Nokia at �49.95http://www.blueunplugged.com/p.aspx?p=120672
Do you think there is any difference between them, i.e. is it worth to buy Nokia's one?
I bought mines for �38 from www dot mymemory dot co dot uk. next day delivery not a problem been great 😊
slawmilcz wrote:Do you think there is any difference between them, i.e. is it worth to buy Nokia's one?
I don't think Nokia manufacturer memory so I wouldn't be at all surprised if the Nokia ones are actually made by Sandisk or one of the other major memory makers.
Arny wrote:I don't think Nokia manufacturer memory so I wouldn't be at all surprised if the Nokia ones are actually made by Sandisk or one of the other major memory makers.
Yeh Amy I think your right, because I bought a Nokia memory card about a year ago in Germany. In its full original Nokia packaging to find the card had actually been made by Sandisk!
slawmilcz wrote:I bought this one:http://www.datakits.co.uk/store/4gb-sandisk-microsd-microsdhc-memory-card-p-3837.html
I have just received this card, and I'm kindly surprised, as I got SD-card reader as well.
