i have an n73 with 2GB minisd card. my phones internal memory is something around 40MB.
i can send any sized file i want using bluetooth, i tested it by sending a 90MB file from minisd.
the problem is when receiving files over bluetooth. the files come in as messages and reside in the message inbox folder.
i like to keep my messages on the phone using the phone memory, so that i dont loose messages when swapping memory cards. so the message folder is limited to approx. 40MB. so i'm unable to receive any file bigger than 40MB via 'BLUETOOTH'
i can solve this problem by using the memory card for messaging(which i dont wanna do).
the other way is moving the BLUETOOTH files to memory card after receiving(that limits the received file to less than 40MB)
so, is there any way that i can keep using phone memory for messaging, but any files received via bluetooth will go to the memory card straight away, instead of going through the phone memory???
cheers.......
