Help needed
4 replies · 1,425 views · Started 28 July 2007
Has anyone out there had this problem. I regularly receive this pop up message.
'Unable to connect to server Vodafone. Continue trying?'
Can anyone help me?
sounds like you havent closed one of your programs and its still running in the background.
turn ya phone off and back on see if it works
rich240477 wrote:Have tried that and it still does it. Any other suggestions?
Install a software like Taskman or FExplorer and close process by process, to found which one do that.
Hi Rich240477
Have you checked your email settings to make sure check interval isn't activated? (usually email settings then select the 1 that says "check for new messages - make sure it's set to off)
