n73 gallery folders!
3 replies · 2,869 views · Started 28 July 2007
hi..
i've tried to search into the forum but I didn't find any answers...
BTW.. is there any way to use folders in the gallery of n73...
it is very uncomfortable to see ALL the images into a single folders...
is it possible??
thx in advance!
hiya mate try this it might be what youre talking about
right open up the gallery by pressing the button on the side of the phone
youll get youre picture
press the options button
select albums
then you can either make a new album to put some pics in or view a previous folder youve allready made witht he pics in 😉
makes finding pics easier and you dont have to do a massive scroll all the way to find what you want 😊
hope that helps a bit mate
Flagro wrote:hi..
is it possible??
thx in advance!
That�s the way that works. only with third part software like Resco photo viwer could be different.
