Animated themes not showing up as animated
6 replies · 8,906 views · Started 28 July 2007
So what's the problem?...It used to work just fine, then all of a sudden the animated themes stopped being animated...I can download them,put them into my phone and then apply them, everything works except that there is no animation...help me out, I miss my animated themes😞
The 6630, 6680, 6681 and 6682 have never supported animated themes as far as I remember. If that's one of the phones you have (as you posted in a forum for those models), then perhaps you remember incorrectly that they used to work.
I think dude, better you goto
www dot ownskin dot com
There have a lot animated theme that u can download it and you also can create one for community
But that animated theme must run with ownskin application, so dont exit that application..
