Pc suite wont browse my n95
4 replies · 2,300 views · Started 28 July 2007
Hi everyone,
New owner of a n95, nice phone.Installed the latest version of pc suite from nokia site but when i try to use the "install apps" section it tells me that I cant list or browse the n95,tried uninstall removing from registry and fresh install but still the same. Is this normal or should i be able to see and browse the phone.When I install a theme it works ok most of the time but would be nice to be able to list everything under the my phone section.any advice appreciated thnx.
cush wrote:Hi everyone,
You should go through the get connected process in PC suite to establishb cable connection and then choose PC suite from the menu on the phone! If you have proper connection you will get a pale blue phone icon in your task bar. You can now install apps!
Note also that PC Suite's Application Installer will not list any apps that are already installed on the phone. You can only use it to install new apps.
If you need to see what's already installed, and wish to uninstall them, use the Application Manager on the phone (not PC Suite).
It's normal. As 'N/A' already quoted; You CAN'T use the "install apps" browser window to view/browse your device. Use application manager on phone to view installed apps.
ok cheers,have managed to install to phone just thought something was wrong when it would'nt browse phone or mem card.
thanks for the advice..
