Case for N95
1 replies · 1,622 views · Started 29 July 2007
I'm after a belt case for my N95 but not sure which to go with
There's this one:
w*w.blueunplugged.com/p.aspx?p=120522
which looks quite good and is cheap
Or there's a proper nokia one:
w*w.blueunplugged.com/p.aspx?p=115387
which is more expensive
I'm thinking of going with the first one but wondered if you guys had any thoughts on it?
Thanks in advance 😊
i got a free leather case when i bought my phone which looks very similar to the cheaper one you've got there.
the stiching on it broke after a couple of days of use.
if i were to buy another i'd spend a little extra and buy the nokia version.
but we all know sometimes you pay for the brand not the quality.
your choice.......
