Hi there,
When connected to a Windows XP notebook, I tried everything I could remember, but can�t use 9210 as an InfraRed modem.
The best I can get is 9600 bits through a serial cable.
No high-speed connection possible so far.
Is this correct or I�m doing something wrong?
Sync also doesn�t work.
Local NOKIA support told me, �Nokia mobiles are not compatible with XP�.
Thanks and regards,
R M Cruz
NOKIA 9210 MODEM / WINDOWS XP
heeeeeeey
i got the same problem sir
plz any body can help in this mattar and thanks in advance
hi,
I am using the modem with serial cable on IBM t 21 notebook. It works fine with HSCD-28,800 kbs. Your GSM provider should support HSCD and enable it for you. After this, is quite simple - you have a lot of variants for the drivers - 9,600, 14......,
Concerning the IR - with PC suite it works(the last version) but, for the modem no chance.
hope it helps,
dorin
[quote]
On 2002-02-22 1515, Anonymous wrote
hi,
hope it helps,
dorin
BUT is it on Windows XP ?
Everyone hates this advice, but format and get rid of XP, it's the worst OS to come out of Redmond since Xenix.
