TomTom problem on N95
3 replies · 2,241 views · Started 30 July 2007
Hi, I am running TomTom version 6.010 on my N95 firmware 12.0.013.
Problem ive got is when I slide the phone to horizontal view it only shows a partial view of the TomTom menu and when I slide it back I just get the normal N95 background and I have to restart TomTom.
Its fine if I keep the vertical view.
Anyone got this problem or know what the screen problem might be?
I don't (yet) use TomTom on the N95 but I believe you cannot switch the view whilst the program is running; you must select your required view before selecting the application!
[QUOTE=you cannot switch the view whilst the program is running; you must select your required view before selecting the application![/QUOTE]
absolutely correct
So, it means that this application does not support N95 feature of changing view with use of slider, doesn't it?
I know many other application which cause the application or even the phone hangs up when slider is moved, e.g. SmartMovie in ver. 3.40 (corrected in ver. 3.41).
