P1i WiFi issues
2 replies · 10,862 views · Started 31 July 2007
Whenever I scan for WiFi networks, the P1i resets itself saying it has restarted to improve performance...has anyone else found this or can anyone suggest a fix?
Cheers, Nick
same here.
got my p1i today, and of course i tried to connect to my office wifi setup.
kept resetting.
i then tried going to a nearby caf�, that have an open network, and i was able to connect without problems.
then i went home, where i also have a WEP protected network, and here too, the p1i rests itself while scanning.
this is really annoying ... anyone have an idea what the problem is?
i am supposedly running the latest firmware, by the way!
thanks for the help.
I found that my P1i will connect to my home network when security is disabled on the router. I have not tried WEP but WPA will not work. The phone did not "reset" when scanning for networks, it just would not connect until I disabled security. I want to use the WPA authentication on my router, hopefully Sony will upgrade the protocols on the phone.
