Hi. I've imported some pois for smart2go software using poixpress. So I've imported speed radars but when I run smart2go (Nokia Maps) on N95 at 90% it stops running. Now I ask You do you know where poi folder is on the program in order to delete some poi and run it faster? Thank you.
Smart2Go and POIS folder.
Don't know, but on a side note can you have an audiable warn when say 100 yard frim the camera, or do they just show up on the maps?
Never tested yet. I can't start the application because of too much pois to load.😡
