Does the Nokia N95 play DivX, by any chance?
Thanks.
Thanks.
Nope.
yes it does - ht tp://mobile.divx.com/ (I cant post the URL because I havent made 10 posts - just get rid of the space.)
I was thinking the samething. So how do you get Divx films to work on the N95?
From another forum.......
"I would convert the Divx movies into the native codecs in the N95 like MPEG4 and AVC.
The reason is simple. Those codecs are accelerated and as such work better and consume less power.
MPEG4 movies at VGA resolution and 30FPS are really good in the N95. There are a number of easy and cheap solutions for easy transcoding, including the Nokia Multimedia Player that comes with PC Suite.
If you have DivX player installed in your PC just open the Nokia Multimedia Player, then open the AVI file and choose Save As... then select QVGA MP4 ulimited size. The resulting video is about 15 fps MPEG4 AVC file that plays good on N95. "
Thanks for that. i will give it a try and see how I get on.
kamaran wrote:yes it does - ht tp://mobile.divx.com/ (I cant post the URL because I havent made 10 posts - just get rid of the space.)
Ok, sorry - not heard of this before. Appologies.
I can recommend Super for Divx conversions - loads of threads on it. 😊
Tip on super- for a letter box movie, crop by 70 on each side and you will get a non distored 4:3 full screen picture on the 95.
Cheers - Thanks alot.
