Nokia N75 Wifi help
7 replies · 5,357 views · Started 02 August 2007
Hi guys,
Is there any way to connect the N75 to a wifi or wireless internet connection. Is it possible with any software installation or anything like that. I appreciate your replies..
Thanq
Prat
prathyushms wrote:but is there any way u can connect to wi-fi... may be installing some software or connecting thru bluetooth?
well you can use the internet via bluetooth on your pc if you wanted to
Bluetooth & WiFi are completely different. You need hardware built in. It's not something that can be done in software.
You can connect to the internet either via your network provider or by connecting the phone to a PC via the USB cable or the Bluetooth connection, although this would require you having a net enabled computer, and if you had that, why on earth would you want to browse on a mobile ??
Still, whatever floats your boat. At the end of the day, WiFi can only be achieved on WiFi equipped devices, and the N75 is not one of those.
