TomTom navigation frozen while instructions
4 replies · 2,541 views · Started 02 August 2007
Hi all,
Have any of you experienced that TomTom (I have TT6.020 installed) freezes the navigation (the arrow does not move) while an instruction is said?
It is very annoying to me and it gives you the idea of under performance in the N95. I have never seen that behaviour in any PDA.
tomtom 6.02 does not support n95 officially (it works but everything 100&#37😉.
i have noticed some slow downs and demo mode some times does not even run.
Ronaldo-9 wrote:tomtom 6.02 does not support n95 officially (it works but everything 100%).
I was referring to the TT behaviour with an external GPS BT receiver of course. then, have you noticed slowdowns when instructions are present?
Talonso wrote:I was referring to the TT behaviour with an external GPS BT receiver of course. then, have you noticed slowdowns when instructions are present?
Same here: slows down when instructions are said . . . 😞
Hope this will be fixed in v6.030 . . . 😮
