N95/Orange/Route66 query
10 replies · 2,715 views · Started 03 August 2007
I have debranded the phone, successfully installed Route 66 and it works fine...however it appears to use 'Orange GPRS'...does that mean I'm paying for it?
busker wrote:I have debranded the phone, successfully installed Route 66 and it works fine...however it appears to use 'Orange GPRS'...does that mean I'm paying for it?
Possibly - Go into R66 settings and set default access point to None.
Also, find nagivation settings within the N95 menus and disable A-GPS as this also uses GPRS connections.
dez_borders wrote:Possibly - Go into R66 settings and set default access point to None.
Do you mean deleteOrange GPRS as an access point?
[QUOTE='[iD];330788']Goto preferences
then to navigation
and under default gprs select No default GPRS[/QUOTE]
Preferences where??? sorry for being stupid)
ffcphone wrote:From the main menu...
Tools -> Settings -> General -> Positioning - Positioning Method
F
this is not what i was suggesting
what i was suggesting was to run route66
press left soft button
select preferences
third tab is Navigation
under Default GPRS select No Default GPRS
[QUOTE='[iD];330801']this is not what i was suggesting
select preferences
under Default GPRS select No Default GPRS[/QUOTE]
Done this...and just found the positioning settings too. They show bluetooth, agps, integrated gps and networkbased. All are ticked apart from bluetooth. Presumably they should all be unticked apart from 'integrated'?
What is the 'network based'? Orange??
If so, maybe I can just deselect that one??
PS Thanks for showing me the 'positions'..hadn't seen that before...must have just come on when Route 66 installed
busker wrote:Done this...and just found the positioning settings too. They show bluetooth, agps, integrated gps and networkbased. All are ticked apart from bluetooth. Presumably they should all be unticked apart from 'integrated'?
Network based check your "Network Cell"
in simple words it is calculted by creating a virtual polygon cell between the mobile antennas around you
you would be ok to leave it checked
[QUOTE='[iD];330810']Network based check your "Network Cell"
you would be ok to leave it checked[/QUOTE]
virtual polygon cell????
Mmm...I bow to your superior knowledge :con?
So I'll just deselect the agps...will report back and let you all know!
Many many thanks!
