How to Install?
2 replies · 1,597 views · Started 15 January 2003
I have a 7650 and have written a Symbian application using the emulator. I would like to take the next step to install the application on the device. What are the steps I need to take to do this? Do I need to purchase a Bluetooth kit (e.g., Nokia Connectivity Card DTL-4 or Socket Bluetooth CF Card) or can I simply use the PC Connectivity Kit that is posted on this website? If someone can let me know the best way to install applications on the phone I would appreciate it very much! Thanks for your help!
If you have made it into a .sis file, then you just transfer it to
7650 with BT, IR, wap, email, whatever.
And install.
