i cant format my communicator
5 replies · 2,394 views · Started 21 February 2002
I think your problem here is OPL, the is a font file names E*.GDR (I forget the correct filename, despite it being a common occurance), simply turn off your communicator, reboot without the MMC in, then insert your MMC and remove the file. You should then be able to continue as normal.
RAFE hurry up and put that hint in the faq/extended manual.....
Sorry SwicthBlade User posted image
I'll try and do something soon. Also you can try searching in the forum. With 3,000 + posts the chances are the problem has come up before..
Rafe
thanx !!!!
but when i choose format
its show me message ( file .......
EON.gdr in use )
help ???
If you installed OPL on to the MMC, then it's a simple case of constantly repeating my above instructions until it lets you delete that file. If you installed it to the internal storage (C) then I don't know how to solve it. Answers on a postcard please......
If you installed OPL on the C drive then it shouldn't be a problem formatting the MMC. If doing as switchblade suggest doesn't work then the only other option I can think of is to use an MMC Card reader and format it in there (or delete the EON file in the card reader and then format it in the 9210).
HTH
