M600i with rogers internet/email
4 replies · 7,103 views · Started 04 August 2007
Hey,
i just got a m600i and cannot seem to get the internet/email to work on the Rogers network in Toronto
i went on the SE website and used the wap wizrd but never got a message ...
entered my number +1647******* and its been like 24 hours and still nothing
is there any way i can set this up manually or am i doing something wrong on the SE page?
any help would be great
thanks!
I'm using my P990i quite successfully on Rogers in Toronto. What settings do you need?
I also tried to use the SE website, but the SMS never came... In the end, I just entered the settings manually.
The key settings, I believe are:
Address: internet.com
Username: wapuser1
Password: wap
Set this up as a Data Account.
You should then be able to access the internet.
I don't understand how you guys set your internet up.
I have been fiddling with my phone for days, calling SE and Rogers.
Still no solution.
No matter what I do, it will not connect to the internet.
Your phones seem to be working, do you guys have any tips?
:con?
