Bluetooth Problem
3 replies · 1,865 views · Started 05 August 2007
Hi all, I have been the proud owner of my T-Mobile Nokia N95 for 4 months and have just encountered my first problem with the handset.
I have lost the ability to connect to anything by bluetooth !
I can connect to the handset from another source and send files but unable to send anything from or even search for other bluetooth devices.
I have upgraded the firmware to the latest T-Mobile have available but problem is still there.
Any one have the same problem ? or is it a trip back to T-Mobile.
Adey Watkins wrote:Hi all, I have been the proud owner of my T-Mobile Nokia N95 for 4 months and have just encountered my first problem with the handset.
1. Did the problem exist before you upgraded the Firmware?
2. After upgrading the firmware did you do a RESTORE operation?
If the answer to either question is Yes, then do the following:-
1. Remove any memory card from the device.
2. Format the handset internal memory, *#7370#
If this does not fix the problem, perform a hard reset:-
1. Power off handset
2. hold 3 * and GREEN buttons
3. Power on phone (still holding the three buttons above).
4. Wait 60 seconds (still holding the three buttons above).
Repeat the above process 3 or 4 times until the handset boots to the Country Selection screen.
If the Bluetooth problem still exists after this, I think visiting a Nokia Care Centre is the best action.
Adey
Take a look at your clock settings and change the seperator to from : to any of the other options such as / or -
This should sort out your bluetooth issues....BTW whats firmware are you on ?
Thanks for the fix hkambo 😊
Bluetooth working ok on all fronts now.
Is there an explanation what happened to cause this and how does the fix work.
Thank you again.:icon14:
Firmware is T-Mobile v11
