Can anyone give me an example of a streaming link for the built in Real Player ? I've tried getting a few streaming links to play, but each attempt yields the same message i.e "unable to play media clip"
Can someone give me an example of a streaming link so that I can test it and also figure out the format of a streaming link
Thanks in advance
dr_razazain wrote:Can anyone give me an example of a streaming link for the built in Real Player ? I've tried getting a few streaming links to play, but each attempt yields the same message i.e "unable to play media clip"Can someone give me an example of a streaming link so that I can test it and also figure out the format of a streaming link
Thanks in advance
have you set up the access point in the real media settings first, you have to do this everytime you use different access points,
yeah, I did set the access point correctly. I'm wondering about the syntax of a streaming link. All the streaming links that I come across on the internet are starting with http://
whereas by default, when you want to enter and save a new streaming link on the N80, the start of the streaming link is pre entered as rtsp://
An example of a streaming link would be helpful
birdman5 wrote:Try this one: (Radio 5 live)http://www.bbc.co.uk/fivelive/live/surestream.ram
If this doesn't work, try
rtsp://rmlive-acl.bbc.co.uk/bbc-rbs/rmlive-acl/ev7/live24/radio5/live/r5_tl_g2.ra
I have this saved as a streaming link.
Hi bro can U give me some other video streaming links address's will be very helpfull. Thanks .
