watching movie on p990i
7 replies · 31,458 views · Started 06 August 2007
Hi, just bought a P990i and am a bit confused about some features. First of all, the FM channel does not change by pressing the button on handsfree ( like NOKIA phones) and second of all is cant watch a full length movie on my phone,I get an error messege every time i convert movie into 3gp. If I convert it with smartmovie, it works fine but the moment i install handsfree, the movie does not play normally! HELP !!!!
I don't know about FM, but you are better of using mp4 as movie format. Just use something like psp video 9 and set resolution to 320x240 and the bitrate to say, 768kbps and it will work ok.
Keep in mind, that if you set the quality too high it will take a long time to start the playback.
pratonline wrote:Hi, just bought a P990i and am a bit confused about some features. First of all, the FM channel does not change by pressing the button on handsfree ( like NOKIA phones)
yes that is an issue, you can not change channel from hands free.
I hope ypu will enjoy after use these steps
1.) Download SUPER converter (FREE on no charge)\
2.) Convert files to 3gp for Sony Ericsson.
3.) P990i default Media Player is capable on playing the files.
candi wrote:I hope ypu will enjoy after use these steps
But how choppy will the videos play?Im trying to get smooth playback or is that un-attainable?My 990i can play all my PSP videos but they all play very choppy.
