To Raven and nawara (help me please)
8 replies · 2,615 views · Started 15 January 2003
I want to connect to internet in my P800 mobile via
bluetooth and my computer. I have Adsl (2mbit) in my computer.
I have downloaded the Java browser and installed it on my P800.(http://www.reqwireless.com/webviewer.html)
I think I have set up my bluetooth connection on my PC and P800 correct.
I can send files between the mobile and computer, so I think it is correct..
But it doesent function...
Can someone please help me.
If you want, you can contact me on icq, 11856523
Or MSN, [email protected]
Alexander Hjalmar
Sweden
Hi, Alexander.
What exactly seems to be the problem?
Please discribe in details what happens, and perhaps I might be able to help you..
Cheers
Raven
Oki, Raven.
When I try to open a webpage in Webviewer this message come up:
Error
Status = -3606
I have contact with my computer. I have tested to send a file
both from computer to p800 and from the p800 to my computer
via bluetooth and this function perfect..
Can it be any settings in my computer Or mobile thats wrong?
I don�t know. Please, help me.
-- My settings in control panel --
Internet-accout: I have not there
Wap-accout: I have not there
-- Hardware in my computer --
I use a 3COM USB adaptor to bluetooth
Windows XP PRO
ADSL 2mbit
Alexander
Yes, I have tested with TipicMe also.
It does not function..
It must be any setting in my computer or telephone?
Please, try help me to find out whats wrong..
Alexander
alle,
i have the exact environment that u described but i succeeded in connecting my p800 to the internet by adsl through bluetooth connection with my computer. the trick is that you should go to the settings or configurations of the bluetooth device in ur pc to know which com ports do the computer use, then in the m router icon of the p800 pc suite locates in the bottom right of the pc window check the com ports that are active. you should now see the p800 icon appears as if you connected it with the pc via USB cradle. At this point u can not only transfer files but also synchronize. Try browsing now with the webviewer browzer, u should catch the pc adsl internet.
[quote="Alle"]Hi,
Alexander[/quote]
You have read all of the posts in the p800 forum about configuring internet sharing? Right?
If you havent read this one: http://allaboutsymbian.com/phpBB2/viewtopic.php?t=6008&highlight=internet+sharing
I'm out of ideas.
der. Try configuring your internet settings on your P800. Download 1 page using WebViewer through GPRS to make sure that you have the right internet settings. Then disconnect from GPRS, and connect your P800 to your PC through Bluetooth. Now open WebViewer again while you're connected to your PC through BT. The WebViewer should now connect to BT in stead of GPRS. PS: You don't have to delete your internet or wap settings to make Webviewer work through BT. Webviewer will choose BT over GPRS as a connection point. Hope I could help. Cheers.i
I have opened my bluetooth device and looked for what com port
then used. The bluetooth device used com 10.
When I open mRouter, this port is not there. Its only
Cable - com1 , Cable - com2, USB - com14 and IR (no com port).
The com10 (that com port my bluetoorh used) is not there...
How can I do now?
Thanks.
Alexander
