Hi everyone,
I a new guy in this group.
Me and my N73 were having a bad week.
First of all my N73 does not want to turn off. I read somewhere that some people are also having problem with turning off their N73 when in Silent mode. Mine does not turn off in any mode.
The only way I could turn it of is by removing the battery. As soon as I reinserted the battery and put the back cover, it turns back on by it self.
Secondly, the battery last less than 24 hours. I have charged the battery for 8, 12, 24 hours no difference. It lasts less than 24 hours.
I have tried to update the software using the PC USB cable however the Nokia PC Suite just does not want to connect with my N73.
Just not sure if this is hardware or software problem.
Any of you ever had or heard of this problem? Any ideas?
Thanks.
