TipicME: Having trouble with ICQ?
7 replies · 1,970 views · Started 15 January 2003
Anyone other than me having trouble accessing their ICQ list with TipicME ? I'm able to access MSN and Yahoo (don't have AOL account).
I had trouble with my Yahoo account. I suddenly had no more access to it. Nothing I tried to solve this problem had any success. Only after I created a completely new account on the Tipic server everything worked fine again. Never had any trouble with ICQ though.
I forgot to say: My problems had nothing to do with TipicME itself. Using the Windows client I was also not able to fix the problem. Perhaps your problem is also Tipic server related?
Ok I just discovered it signs me into ICQ but I am not able to see my contacts. I knew this because while having my ICQ client on, I signed into Tipic and it signed me out of the ICQ client saying it's being used on a different computer.
That's ok then! Getting the ICQ contacts from the ICQ server is just not supported (with AIM this doesn't work either). You have to add your contacts manually, then it should work. Btw I have noticed that you must not rename any of the contacts! For some strange reason it is not possible to see their online status then...
I renamed my contacts and I can still see their status. Maybe you renamed the wrong field. You rename the last one (I think its called Nickname) but it's the last one out of 3 fields.
Yes. I am sure there are something going wrong with Tipic server itself.
Sometimes I get MSN and not icq or vice versa.
Actually if you notices, it also doesnt work 24hrs.
Maybe Tipic could explain on that.
