Versions of Excel for use on N95?
5 replies · 11,263 views · Started 07 August 2007
I want the N95 to replace my Pocket PC, but one of the main things I use on my Pocket PC is Pocket Excel (which I can sync with MS SPreadsheet on the PC). Is there a version of Excel I can use on the N95 that will sync with MS Spreadsheet or Excel?
Not sure what you're after here but N95 can open *.xls documents (Read only. If you want to be able to create/edit you'll have to buy an upgrade to the built in Quickoffice).
superswede wrote:Not sure what you're after here but N95 can open *.xls documents (Read only. If you want to be able to create/edit you'll have to buy an upgrade to the built in Quickoffice).
Do you mean the upgrade that is for example available from the online shop here the Quickoffice Premier v4.5 (Upgrade)?
If so, do you or anyone else know if it is compatable with MS Spreadsheet? At the moment I open Pocket Excel documents with MS Spreadsheet, I don't have desktop version of Excel.
nickmon wrote:Do you mean the upgrade that is for example available from the online shop here the Quickoffice Premier v4.5 (Upgrade)?
Yes. N95 comes with Quickoffice v.3 (read only version). You can upgrade to either v3 Edit mode (about $20) or to v4.5 Edit (about $40). More info: "quickoffice.com"
About comp. with MS Spreadsheet. As I am unfamiliar with MS Spreadsheet perhaps you could PM me a MS spreadsheet and we can test if I can open it on my N95.
