Install Apps on N95 problems?
3 replies · 4,312 views · Started 07 August 2007
Hi, ive been looking but cant find solution anywhere, hopefully you guys can help?
N95 Cant install games
Hi im trying to insatll a few apps and games, to my N95 using apps insaller on the PC suite, but they only get 90% of the way then i get an error msg.
I can install themes, as ive switched the settings to ALL and online cert to OFF, but the games still vex me, any ideas would be fantastic, cheers.
Glenn
glinja wrote:Hi, ive been looking but cant find solution anywhere, hopefully you guys can help?
Glenn
Are you sure its an error message? After about 90%loading with the PC suite, you must look at your phone and continue installing from there (at least that's what I found). The installer doesn't go all the way, the phone takes over
And in addition you have to make sure that the apps/game are for S60 3'rd Edition and not an older version (like Symbian 8.x/2'd Edt which was used on N70 etc..).
hi, yes they install ok from pc, then it asks to check phone, i can then choose to memory card or phone, ive tried both.
This is when they load 90% then the error message appears.
How do i know if the games etc are N95 compatible, apart from this error message please.
Many Thnks for response
Glenn:icon14:
EDIT>> ps these are Java apps and games not sis games sorry for any mis information 😉
