Firmware problems with N95 - Part 2 (getting swe pack)
5 replies · 2,530 views · Started 08 August 2007
Hello!
This is a follow up question to my other thread, the reason why I started a new thread is because it's another question (connected to same theme yes, but still different) and no avoid confusion when using search function in forum.
I changed the product code to euro 1, an English version because I didnt know other codes. Today I tried to change it to an Scandinavian supported code for N95 Plum; 0536068, which was succesfull. Then I re-downloaded and installed the update from Nokia updater, but I still didn't got a Swedish supported version.
How do I reset the firmware so I can have swedish text? (Used to have a product code from Three (3 sweden), then an english EURO1 and now Scandinavian, the last two was both in english after update.)
Thanks,
Oscar
you've put the right firmware version on .. you need to goto tools/ settings / general / personalisation / language .. and instead of automatic .. choose Swedish for both Phone language and writing language * minor correction .. Changing just the Phone language will also change the default writing language *
(I guess it should be available if you have the right version of the firmware)
the phone will restart .. you should then have menus etc all in Swedish..
Good Luck!😊
seki wrote:you've put the right firmware version on .. you need to goto tools/ settings / general / personalisation / language .. and instead of automatic .. choose Swedish for both Phone language and writing language * minor correction .. Changing just the Phone language will also change the default writing language *
Good Luck!😊
Ehum mate, that's kind of my problem, I changed the product code so when I downloaded the latest verison, it didn't got support for Swedish text etc, beacuse the key I entered was one which only included english, france, german, spain and italian language 😞..
So maybe I'll have to try to install an older version, then try to donwload the new one agian, and hope it will include Swedish language since I've change the code agian to a Scandinavian one.
guwd wrote:Ehum mate, that's kind of my problem, I changed the product code so when I downloaded the latest verison, it didn't got support for Swedish text etc, beacuse the key I entered was one which only included english, france, german, spain and italian language 😞..
This code should do the job:
Sand: 0534847 SCANDINAVIA
Plum: 0536068 SCANDINAVIA
NEVER downgrade your phone, because it'll make your phone useless!!!
henklbr wrote:This code should do the job:
* How do I reset the firmware so I can have swedish text? (Used to have a product code from Three (3 sweden), then an english EURO1 and now Scandinavian, the last two was both in english after update.) *
Once you have re-installed the latest firmware using a code from henk's list above .. your phone will restart
BUT by default it will be in English .. you must then do what I suggested to change the Phones Language - and SWEDISH will be in the list, or you've got the product code wrong. Hope you sort it!😊
Cheers!
First it didn't seem to work, and I was just on my way to post a new reply with a conclusion which I made up. Then I double checkd the NSS so that the product key really was the new one, I saw a misstake! I had copied the new one listed up here (thx henklbr), and pressed write and it confirmed it was done, BUT, I hadn't clicked the check box wich says "Enable". I re-wrote it and ran the software update once agian. And as a good suprise (this was included in my conclusion, the updater have to, imo, download some new stuff so it can support swedish), it started to re-download the update! 😊 And my phone was succesfully updated.
Thank you for quick answers 😊
Oscar
