n95 maps query
3 replies · 2,293 views · Started 09 August 2007
hi all, i have a question about the nokia uk maps on a new n95 the question is do anyone know if the maps of the uk are already installed in the phones memory or do they have to be downloaded because i installed the nokia maps downloader onto my pc and it didnt have just uk maps on it only european which said needed more memory than i have available in my 1gb memory card, also do i get charged if i download them by any method other than usb cable or w/lan via my pc, sorry to be a pain but need to clarify exactly what the situation is as i am a bit confused and the user manual doesnt go indepth regards alfie1:frown:
Yes, as neilhoskins says. You first select "Europe", it will then expand and show individual selectable countries.
Attachments: NokiaMapLoader.jpg Europe.jpg
