nokia maps
3 replies · 1,543 views · Started 09 August 2007
hi guys i wonder if anyone can help me, i have just downloaded uk maps via my pc to my nokia n95s micro sd memory card, my question is how do i open the maps from the memory card all it tell me is the memory is gone down by 125 mb so i know its installed them ok how do i find and open the application or can't it be done this way as i don't want to be charged for viewing various uk locations hope someone can help me, just to let you know i downloaded them via nokia maploader connected device to pc via the usb cable 🙄
alfie1 wrote:hi guys i wonder if anyone can help me, i have just downloaded uk maps via my pc to my nokia n95s micro sd memory card, my question is how do i open the maps from the memory card all it tell me is the memory is gone down by 125 mb so i know its installed them ok how do i find and open the application or can't it be done this way as i don't want to be charged for viewing various uk locations hope someone can help me, just to let you know i downloaded them via nokia maploader connected device to pc via the usb cable 🙄
Opent he Maps-program; if you can see your location where you are, the map is correctly loaded and saved on ur memory-card ! 😉
what happens if i don't grant the access to the network (in the nokia maps preferences) to the AGPS? it still works?
cinghialino wrote:what happens if i don't grant the access to the network (in the nokia maps preferences) to the AGPS? it still works?
Yes, but the time you'll have a fix will be longer!
With A-GPS enabled, I've a fix in about 20sec, even inside!
The data received, with A-GPS enabled, will be about 5Kb . . .
