Hey guys, i've had absoloutly no luck with finding navigation that works on the n91. I tried tomtom which crashes. I've tried routee 66 but I keep getting some resource error, which ppl tell me is because i have no maps, but i d/l aussie maps and i still get the issue. I've tried nokia maps but i have to be constantly connected to the net which sux.
so in short can anyone direct me to somewhere where i can dwn load navigation software that works on a n91 with australian maps please!!!!
route66 mobile 7 is your only option.. but much better than tom tom mobile
you just have to make sure that the maps are in the right place and the fonts folder is also in the right place..
folders should be placed on the phone memory like such
e:\system\fonts
e:\system\apps\route66\maps
e:\system\apps\route66\lang
e:\system\apps\route66\res
e:\system\apps\route66\speech
e:\system\apps\route66\activation.dat
etc etc etc
if they are not in that order they you will get resource error..
you will need to use storage mode and your pc to make sure, or if you have y-browser or activefile you can check with htem
Have you tried VITO SmartMap? Please visit nclubsoft dot com for this and see if this application serves your needs. You will need to download and install two applications:
1). VITO SmartMap
2). VITO Map for Australia
