delete applications on phone memory
4 replies · 3,230 views · Started 10 August 2007
does anyone know how to delete any applications which are pre installed on the phone memory of my nokia n95
Did U try a browser like Xplorer or Y-plorer and try 2 delete the apss on the install en apps folder on C?????:con?
Such apps will not be usable for deleting installed apps (no file manager that runs on the phone will have access to the system directories/folders and the application private directories under \private).
Preinstalled apps in ROM (deleting means a directly/folder has to be rewritten, and ROM = Read-Only Memory) cannot be deleted/removed at all.
Those that can, you can uninstall with the Application Manager (App.mgr in the Tools menu).
freshman wrote:does anyone know how to delete any applications which are pre installed on the phone memory of my nokia n95
You can only delete themes. ringtones and the welcome vid!
Why and what do you want to delete?
