Is it recommended to do software update?
3 replies · 2,483 views · Started 10 August 2007
hi
got my n95 yesterday, how do i check which software version i have?
also, if i find it to be out of date, is it recommended to do the software update found at europe.nokia. com /softwareupdate
thanks again for any help
cheers
Jon
alldayidream wrote:hi
cheers
Jon
You can cjeck your firmware-version by typing in the stby-screen *#0000#
With firmware 12, you'll have a faster GPS-fix !
ok, ive got v 11.0.026...is it worth an upgrade?
in order to upgrade this firmware, i take it i have to change phone code and thus invalidate warranty right?
the software update at the link i posted...is this what i need to do?
You'll only have to change prod.code if there ain't any newer firmware out for your code.
Easiest way to check: Run NSU and it will tell you if there is any to update to.
