mine is 1.2.2.15. What is the latest driver version for the MSI Bluetooth USB key?
What is MSI latest driver version for Bluetooth?
Mine is 1.2.1.20. Where you got this version? Via download or from the cd?
[quote="cgo"]mine is 1.2.2.15. What is the latest driver version for the MSI Bluetooth USB key?[/quote]
You can download the 1.2.2.15 from http://download.msi.com.tw/support/dvr_exe/bt45.exe
so 1.2.2.15 is the latest?
Yes it's the latest.
Thanks for sharing the information.
Download Billionton's latest bluetooth drivers at
http://www.billionton.com.tw/extra/download.htm
Version 1.3.2.7.
No more problems!
Direct connection to your phone. No need to use the serial port first!
I use both Billionton and MSI bluetooth USB adapters.
The software and drivers work for both brands!
66 MB for the billionton driver????
What did they put in there? Is it Widcomm stack?
manuals, guides, etc.
Yes it uses Widcomm stack.
You should definitely try it... NOW! 😃
so it is compatible with MSI's USB? I am just a bit worried with the settings coz it wasnt easy to set it up the other day. I'll take the risk and try it now
