Non Existing Headset/enhancement problem.
3 replies · 7,046 views · Started 11 August 2007
So, my one big problem with the Nokia n80, is the slider, which doesnt lock so when it is in my bag, it tends to open up and go to music player or other things.
Well, this time it has gone and activated enhancement for headset. I tried disableing it in settings - phone - ehancements but I get only three options headset, text phone and some other. Ive also lost sound due to this. I am able to make and recieve calls, it vibrates but I can not hear anything.
Ive tried resetting my phone twice, however it never take sit off headset mode and this is driving me nuts.
Any ideas on how I can fix this? Is there a way to tottally reset the phone? Including Data and things...anything is viable for me now with this problem. Thanks!
yeah, have a search on the forum.
The soft reset and hard reset codes are mentioned here many times.
The problems doesnt sound familiar.... when you say no sound, do you mean you cant hear the caller or that you cant hear the ringtone??
Do you have anything stuck in the popport?
I've not heard of this on an N80, but on a colleague's N73. You could try re-flashing the firmware if a hard reset hasn't worked. If you've not done this before, take it back to your retailer - my friend did that (she didn't want me to do it, charming) and it was sorted for her.
This happened to me yesterday. Headset icon, no sound...
I basically had to plug in the headset, and then remove it. The icon cleared instantly.
