Nokia Maps on N70
2 replies · 3,021 views · Started 11 August 2007
I've installed the Nokia Maps on my N70, no problems there. But whenever I try to connect to my BT GPS (Holux GPSlim) it just won't work!
My BT GPS works with nav4all with no flaws, but Nokia Maps finds my receiver but can't connect.
Anyone experienced the same problem, with a solution?
/N
Just to let you know I have exactly the same problem and am looking for a solution also. Just so you know it's not you, your phone or your HOLUX GPS unit
