Problems with Updating N95
3 replies · 1,908 views · Started 11 August 2007
Hi!
I decided a few days ago to update firmware on my N95. I downloaded nokia updater from the website, connected my N95 but there is a problem. My current firmware is 10.0.018 RM-159.
Updater is saying that I have the newest ver of firmware. I live in UK and got my N95 from Orange. Can you advise what might be wrong?
Kind Regards
Robert
Sofist wrote:Hi!
Kind Regards
Robert
Ok, it means you have the latest Orange update on your phone!
If you want to upgrade before Orange release their update you will have to change your product code with a prog called NSS! This will give you the 'power' to debrand and get the latest straight from Nokia upgrades as and when they are released and this will be before the net ops release their versions!
It's not difficult! Try a search on upgrading or debranding!
