sory, if my english is not well enough and sorry if i'm in the wrong place to ask
i'am ary
i want to ask some of my problem with MMC for NGAGE QD
my MMC is eagle tec 512 MB
my problem is, i can't copy more than 100kb file from local phone ( C: )
to my MMC but if copy from MMC to C:, it can.
if installing a .sis file that result content is file more than 100kb, it can't also
what must i do? plis for your help 😊
is that format type wrong? i'm format it with FAT (via computer)
anyone have a software that can format the MMC? because i can't format it from my ngage
(i dont know why but when the process is half on it, it say 'memory card error', then i format it via computer with MMCmedic)
But my problem above is not solve yet
thnks for your help 😊
You should try to format the card inside the phone. But seems also, that the phone does not work well.... Do a Backup and a soft format first, with *#7370#. It should work well after.
nj7 wrote:You should try to format the card inside the phone. But seems also, that the phone does not work well.... Do a Backup and a soft format first, with *#7370#. It should work well after.
Brother NJ, thanks for the attention.
But....that's the problem
i say above, that i can't format those mmc via my phone,
when the process still half on it, it seem alert "memory card eror"
that's also i have do the soft format for my phone..
any other idea?
I understand that! It�s because of that, I said, format the phone. After, try again, format the card inside. The phone my have problems, but could also be a corrupt card:frown:
nj7 wrote:I understand that! It�s because of that, I said, format the phone. After, try again, format the card inside. The phone my have problems, but could also be a corrupt card:frown:
bro NJ,
there is no big different after i format my phone n my card.. 😞
but now i can copy file with size up to 100kb but less than 150kb,
when the file is up to 150kb, it still can't.
thnks very much for your help, maybe i should buy a new one 😞
