Leather Pouch/Case to hold N95 in Proporta Crystal Case
0 replies · 2,287 views · Started 12 August 2007
I am loooking for a leather pouch/case to hold my N95 which is already covered by a Proporta Crystal Case.
:con? Why you may ask? I have found that the Crystal Case does not soften against impacts and thus the outside might be safe but the N95 may take internal damage... don't laugh at me it has happened 😞
So put aside your skepticism or criticisms:con?
The better the fit over the Crystal Case the better and price is not an issue!
Thanks!
P.S.: Will have a crystal case and then a leather case interfere with the Bluetooth? It shouldn't be just double checking.
