Problems with the menu
3 replies · 1,760 views · Started 12 August 2007
Hi there,
strange......
When I enter the menu only the first 2 rows appear en the 3rd row has shows the folders I created in the 5th icon of the menu (BEFORE THE ERROR). The fourth row has dissapared.
What must I do?
I can't reset the factory settings because I put the settings option in a folder that has dissapeared.
I use the 4gb micro SDHC card....
Switching off and on doesn't work.....
Pleae help because I am leaving 4 holiday in 12 hours and need 2 have the phone working properly.....
Remove the battery and the card for a long period, like 1 hour. Try again without the card. Insert the card. If that does not work, format the phone with *#7370#
Also problems (like posted B4) with *#0000#, *#7370# or *#06#....
There4 no hard reset possible....
Think I will format the N95 and curse again because of that lame V.12 firmware.......
* GREEN and 3 while powering on I take it .. and .. take out your card just in case
- I'd be backing up your memory card to PC ..
Good Luck!😊
