[FONT="Comic Sans MS"][SIZE="3"]I have that Nokia 6630 on which i can easily use the web and wab to surve the Net, the Problem is with the MMS messages. Easch time i try to send an MMS i Get this Message (Max. number of connections in use. Close an active connection first). and if someone sent me MMS i get this message (MMS waiting. Close Connections to receive message?) actually in both cases I'm not using any connections just the MMs connection trying to connect. I did configure the Access points rights as the one on my friend who the MMS works with well. Can someone help me fixing this Prob. ?? [/SIZE][/FONT]
MMS Message error with Nokia 6630!!!
Search for any background software that�s trying access the connection. You can use FExplorer for that. "Kill" the open process and change the software who is doing that.
go to menu > connect > connection manager
if its display 1 connection or something, just disconnect it and start mms
If its display no active connection, so your phone is i dont know
try reformatted it and dont forget to backup
