Nokia N95 Software question help !!
2 replies · 2,019 views · Started 13 August 2007
Hi , can anybody help me ? ive been searching for a programme or software especially for the Nokia N95 or symbian s60 3rd edition, well im sure ive seen it somewhere and apparrantly you can Talk into the mic of the phone and then send it as a text message, sounds great but now i cant find it anywhere !! Should have saved it in favourites !! This will also save the time of typing text messages,
The next one im looking for is the full screen caller for the N95 And i believe its the new version and not full screen caller as it was called, so if anybody can help me find the above 2 software programmes id be very greatfull, even done a google search, but im sure some of you already have it and can let me no what and where to get them..
Also is there any other text messaging programmes out there that enable you to view when the last text was sent , ie time/date as the N95 Does not support this !! Most frustrated,
Thankyou and hope to hear soon from
Brian
readbmr wrote:Hi , can anybody help me ? ive been searching for a programme or software especially for the Nokia N95 or symbian s60 3rd edition, well im sure ive seen it somewhere and apparrantly you can Talk into the mic of the phone and then send it as a text message, sounds great but now i cant find it anywhere !! Should have saved it in favourites !! This will also save the time of typing text messages,
Brian
Cant you use the built in voice recorder, then create a MMS and insert the recorded voice clip into that?
I'm pretty sure you can and there is no additional software needed.
Full screen caller = skye caller pro http://www.skyestream.com/
and sms diary will tell you about sms but this is built into the nokia as well.
Just goto the built in log and select the last tab, here you will find all calls/mms/sms in and out with date and time stamps for a max of 30 days, just click on anyone of them to get more detailed information
sms diary = http://www.olamelen.com/
Hi and many thanks, kive just downloaded the skyecaller and yes its great, i didnt go for the skyecaller pro as im hoping i can upgrade it later, also i will try the sms diary and again many thanks from brian.
