hi
basically i have been trying every day to get my wlan to work and cant. have phoned o2 and they said that bt can help, but of course i phone bt and they say that its o2's issue.
have tried every tact i can, being nice and being forceful and they just cant help me
i think i need to start from scratch in order to get all the right settings on both phone and router...is there an idiots guide anywhere? or could someone just tell me what to do please?! sorry for sounding desperate but ive been trying everything i can every day since friday and its just not happening! ARGH!!!
thanks for any help at all
Jon
ok but what exactly is the issue (what do you do and what do you see??)
alldayidream wrote:hibasically i have been trying every day to get my wlan to work and cant. have phoned o2 and they said that bt can help, but of course i phone bt and they say that its o2's issue.
Jon
Ask BT to talk you through disabling all Wi-fi security on your router, then if you still can't get your N95 to connect, it's probably faulty and needs TLC at an NCC
Remember to re-enable the security on the router afterwards...
basically i get a 'web; no gateway' reply whenever i try to connect. can find the network no problems, but browsing is not possible
thanks for your help so far chaps!
remove encryption from ur router then try.
after working, set the encryption to WEP
test then do not change router settings.
also, update firmware in phone if possible
menu > Tools > Settings > Connection > Wireless LAN > Options > Advanced settings
Then answer "Yes" to the "... Continue anyway?" prompt and then change the "Automatic configuration" to "Disabled" and then disable "Power saving".
